Remove Power Steering
    anyone ever figure out how to get it all took out yet =D ? or how i can plug some of it cause im gettin pretty sick of the power steering shit under my hood and im not even using it.
    Project EX Coupe Coming Soon...
    ..::Built not Bought::..
    eihter ...
    1) pull out the belt thats going to the power steering pump.
    2)pull the belt and pump,hoses ,lines and main bolt of the power steering rack
    drain...
    1) theres a special machine that takes removes the power steering fluid
    ......remember this is at your own discrestion
    turn the key,Clutch-Gear-Gas ..Gone.... R.B.
      Cut the power steering lines at the pump leave about 1-2 inches on the line, take like lines off, fill them with jb weld, then fill the pump with lithium grease, screw the cut line back in after you let them dry for about a day or two. Then go ahead and remove everything else, alot easier if the engine is out.
      CB7
      Removed:A/C, P/S, C/C, ABS, Wires, Battery
      Added: H22A, South Bend TZ Series Clutch, Fidanza (8lb) Flywheel, Megan 4-1 Headers
      Waiting For:M2F4 Tranny, NX 50 Shot
        wow u made it sound so fucken much easyer some people go into pages and pages how to do this u got right to the point thanks man going to pick up some jb weld tommrow
          i just took the pump out and cut they hoses looped the hard lines on the fender and plugged the bigg one with a bolt
          member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
            Hows this JB weld stuff work i've never used it befor but i've always header of people using it for stuff. i asked a buddy of mine today he said you gotta get 4 tubes and mix it? anyone gimme the 411 on JB weld
