h22 question
    h22 question
    ok i have just two questions:
    the h22 drops right in to the mounts right?
    Upgrade your mind before you upgrade your car
    "So. Cal OUTLAWZ "
    yes using your accord mounts and brackets
    Members Ride
      I thought there was a issue with the transmission mounts? Something about using a prelude 5 speed transmission mount, I could be wrong. Im wrong alot lol.
      I cant Slam further. The ground refuses to get any lower.
        you would have to tap the tranny if its an h series tranny then you use your accord mount,
        Members Ride
          if using the prelude transmission, theres 2 holes that need to be drilled/tapped in order for the accord bracket to mount to it.
          My Members Ride Thread
          You have to think outside the box to get IN the box!
            Depends if your auto or manual. Manual will drop right in with tapping as mentioned. Auto needs a mod on trans mount if you swapped to manual if auto the stock mount should suffice.
