Civic Radiator?
    Civic Radiator?
    Will a 1/2 size civic radiator run ok in are cars? cause i've seen swap hatchbacks with the 1/2 size radiator in them and if i can run a smaller radiator i'd be pretty happy. So is it ok to run one or what?
    Project EX Coupe Coming Soon...
    ..::Built not Bought::..
    civics run h22's with half radiators no problem, id assume itd be perfectly fine.
      Just make sure its an extra thick core to help make up for the loss in surface area.
        alright sounds good to me guess ima pick one up here in the next week and see how it goes.
        for some reason im on this kick to open up the engine bay as much as i can not sure why jus looks sexy empty i think lol.
        but yea thanks for the info mike
          Good luck man. Take pics when its installed. Im thinking of doing the same thing. My rad now is pretty beat up and my turbo is too close for my liking.
          Elite Concepts
            You need a dual core civic radiator. You get the single core your gonna overheat.
              Let me know how it goes cause I may follow suit cause my radiator is leaking
              This Car Is Killin Me Softly
              In This World Killin Me....Softly.........lol
              F20a Funds: $0.65
              Need : $500.00
                This mod is only recommended if you do NOT have AC. Unless you can somehow rig up the fan to sit on the condensor which shouldnt be hard. 99% of the people that do this have boosted setups and no AC. Only turbo setup I have seen with AC is iamanonymous car with a full size koyo.
                  yea i was thinking of getting the thicker one but couldnt member the name thanks.
                  but yea i'll get some pics up soon as i get it put it and let you know how it works
                    when im going to be running turbo. im going to run a/c with the civic rad to make some room to run the intake pipe from the turbo and run the intercooler lines.
                    miss my turbo cb7
                      alright i order a 95 dual core radiator to put in my car. hopfully i'll have it by this weekend and i'll get some pics up asap.
                        dual core rad and a high powered fan at least 12inch the bigger the better with manual thermo switch and set it to run at a low temp and you should be good to go
                        good luck
                        i went over 88mph and its not even yesterday
                        second try 112+ mph havent even gained 5mins
                        stupid fluxcopasitor damned DMC parts
                        my thread
                        comin at ya
                          good luck
                          also buy a 160 degree or below thermostat to make the cold cooling flow quicker into the motor.
                          miss my turbo cb7
                            just get an automatic civic radiator its thicker.
                            if you got something smart to say, guess what, i dont care.
