Help Regarding Spark Plug Replacement.
    hello, i have a 91 accord [f22a4] engine. i'd like to replace the spark plugs, but i don't have a torque wrench. the manual says: 13lb-ft of torque. other research on the web says, w/o a torque wrench, fingertight then 1/2 turn, or with tapered seat 1/16 turn.
    i'd like to know, is it 1/2 or 1/16 or neither. if neither, how many turns is equivalent to 13lb-ft of torque? thanks.
    A torque wrench is a worthwhile investment, considering how much it could cost if you had to fix a stripped sparkplug thread. they are like 30 bucks to buy, but yes it can be done this method, usually hand tighten then a quarter to half turn...youll get the feel of how tight it needs to be...but why not just buy a wrench and be sure.
      thanks so much for the input. and to answer your question...money. thanks
