Maintenance Help
    Maintenance Help
    I own a 1990 Accord LX Automatic w/ 177k miles on it. What maintenance needs to be done assuming that you don't know what maintenance were done on the car beforehand. I'm thinking about doing a motor oil change, transmission fluid flushed replaced with Honda ATF fluid, replacing spark plugs, replacing distrubtor cap, replacing fuel pump?, replacing air filter, replacing everything that has to do with the timing belt... which would be? Any input would help. TIA!!
    Oil Change
    Transmission Fluid change
    Valve adjustment
    Replace spark plugs
    Replace power steering fluid
    Replace brake fluid
    Adjust e-brake
    Wheel Alignment
    Fuel Filter Change
    IACV Cleaning
    Replace distributor rotor and cap
    Replace Spark plug wires
    Test battery
    Radiator Coolant change
    Air filter replacement
    Tir rotation
    Check and adjust drive belts if necessary
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      thanks! pretty much sums everything up that i could think of. so i just need to adjust the drive belt, not replace it? i'm just comparing maintenance to my other cars where i need to get the timing belt, timing chain, etc replaced along with the components it's attached too. TIA!!
        You hafta inspect all belts for cracks and wears. If there are signs of wear and cracks , replace them. If not , just adjust them.
          okay. makes sense... thanks for the help bro! where in the bay area are you located?? might as well inspect/ show me the ropes to my car.
            Im at Santa Rosa , 45 minutes from Vallejo and 1 hour from The City.
              oh whaw. you're up there! ahaha... i'm from sf/ east bay at times. maybe in the next meet that's close by i can get some help from locals.
                Yep , and it sucks to be as far as hell from all the action.
                  actually wanted/ thought about going to the meet... diablo one? but i don't think my car can make it that far considering the oil leak and tranny problems. well the tranny isn't much of a problem. it would just grind from dead stop to starting and would only have a delay of shifting if i drive the car hard. if i just do regular driving, shifting is okay. hmm, so sometime this week, i'm going to get a distrubutor cap/rotor replacement along with fixing the o-ring if that's the problem with the leak, replace spark plugs and wires, replace air filter, flush tranny fluid to be replaced by honda atf fluid, tighten drive belts then i should be good? oh yeah, need to either replace or fix a part of my a/c unit 'cause i don't know if i have a leak or the a/c compressor is out. btw, what does IACV stand for?
                    You should bring extra quarts of oil and ATF just in case you wanna go. how bad is your leak? If its dripping like water then don't go. IACV means , Intake Air Control Valve. I would duggest that you change your A/T fluid and see what happens.
                      okay. so i have that extra bottle of atf fluid. can i just pour the whole thing in there? or do i have to drain the previous fluid? i just want the car somewhat driveable before i do the whole maintenance thing at the shop. the leak isn't that bad where you can see it dripping at the bottom. but the whole tranny side is sludgy looking... black gunk... but when i touched the bottom of the distributor cap, it was wet from the oil.
                        For the Tranny fluid , you have to check first if it's full or not. If the fluid is brownish or black , than you definitely need to drain the bad fluid and put on a fresh batch. If it's reddish then you're ok. The distributor , you have to change the o-ring before it floods other components.
                          thanks! makes sense... anyway, i'm not home and the car isn't with me. reason for these questions that i could check upon myself. but when i take off the tranny dipstick, is there a gauge showing that i have too little or too much fluid like the in motor oil's dipstick?
                            yes there is. There are two lines , in between them is like a criss-cross pattern. That's the level indicator. If it's in between those lines of course you have to add some cherry juice (ATF) in it
                              ahahah. okay. how much does a bottle cost? so the car was handed down to me recently. remembered finding an atf bottle in the trunk along with the long funnel. so i'll probably check it later today. but i should just wait until i finish the whole maintenance instead of wasting a good bottle, shouldn't i?
