A/C Removal
    A/C Removal
    I have searched for the topic and have came up with nothing if anybody has any information on the subject please inform me, it will be of great appreciation.
    Thanks: Mike
    Clubcivic.com: Maiku
    Clubintegra.com: TougeRunner
    Have you pulled another CB7 out of a ditch with your CB7? I have ....
    Whats so hard about it...Draw out the system unbolt everything really not much to it.
      In all honesty, I'm just trying locate all the components lol
      I'm trying to find out if I need to have the car lifted up to remove some of the components, because if that is the case, I will need to take it to a buddys house.
        you shouldn't need to set the car up on a lift, most of the parts are easily accessible from the top of your engine. However, if you do feel the need to get under the car for whatever reason small ramps for which you would use to change your oil should be more than enough lift.
        bear in mind you will need a new belt after you remove the a/c components.
          only thing that is low is the a/c compressor once you take that out you can just unbolt the lines and go on or if you want to test is out then you can just bypass the a/c compressor with a dx belt and leave everything intact.
          Dont drive faster than your gaurdian angel can fly
