how hard and expensive is it to repair a flywheel in my car.
90 A/T flywheel
yes, it would be hard and expensive.
underneath the car, next to the oil pan, mounted on the side of the transmission is a black metal plate with a couple 10mm screws holding it on. its the "flywheel cover" that covers the lower back edge of the flexplate. if you dropped something in there, thatd be an easy way to check.
Yes i did, it was soo embarrising hella loud clanking then finally it just gave out and stopped turning.Originally posted by Leungdo you hear something clinking around in there?
i guess that would be a good enough reason to keep that rubber stopper thingy where it's suppose to be if you're not checking the timing of the engine.
and my car didn't have the little rubber stopper when i got it
iunno i just think something got in the little hole that you check the timing. but would the whole motor have to be lifted out of it to fix it or what.
