weird problem after installing SRI
    I put in my ebay SRI yesterday, hooked the vacuum lines up just how they were, and now my car has a pretty bad shuddering problem at idle and low rpms. I quadruple checked the 2 vacuum lines comin off the intake pipe and they looked golden. Any ideas what I could have bumped? Also smells a little on the rich side... What is the silver valve on the drivers side of the IM that has the small vacuum line from the intake going to it?
    bump. any ideas guys?
      I remember I had a similar problem when I installed a SRI for my first time when I was in the eighth grade. It turned out I damaged some of the vaccum lines that run out of the black box. So make sure you didn't do the same.
      Originally posted by kc8enb07
      does it come w/ jdm trash? they better throw away gold in it
        May not hurt to check and adjust (if needed) your engine idle speed.. Later
          Ok i just recently found the culprit to mine, but it was harder because I didnt take the engine out and had no idea were anything went.IF looking at the motor fom the front and on the right side of the intake manifold there is a little valve i guess, it has a spring in it.With a single vacume line coming out of the top.I had capd it off, there should be a small vacume line running to the left of the mani.Dont clog this, i completely took it off and its running great, this was also the reason 2nd,3rd and 4th on my auto tranny wouldnt realy go.
            good luck figuring it out...
            i hate vacuum leaks...they are annoying are hard to find...
              One goes from tb to the lil black valve deal on the fender area. Just take all that off its useless HOWEVER follow that vac line and plug up the hole it went to.
                I'd rather just see a nice picture or two of the setup. Its hard when I can't see it and he's not even sure what he's looking at. :P
                Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
