engine rocks back and forth when stepping on gas
    okay so my engine will rock back when i step on the gas, and will go back to sitting position when i let off my foot. i just finished my swap, and i dont think i retorqued the rear motor mount entirely correctly... could my rear motor mount not be torqued enough to cause this problem? or my front ones? thanks.
    well it depends because if its auto, its controled by the vacuum line so check that but in most cases its the front wishbone mount that causes it 2 rock like that
    1990 Accord EX Sold
    1995 Accord LX V6 Stored
    1999 Accord LX Daily Driver
      hmm yeah broken/old engine mounts will cause unwanted engine movement. they arent cracked through are they??
      does it just move when u step on it, or is it a constant rocking back and forth....
      reason i ask, is that if you did a timing belt job on it and the front/rear balancer shaft gears are off, it will cause engine vibration and sort of a wobble...but thats more at idle.
      id inspect ur mounts...and make sure u tightened them down to spec.
      good luck
      F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
      Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
      Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
        i replaced the front wishbone motor mount cuz that one broke completely... its not a constant rocking, its just that it will move/rock forward when i step on the gas pedal.
          inspect the rear mount. unless ur mounts are filled or have urethane inserts, you should expect to see some movement when you step on the throttle! oem mounts on our accords arent strong by any means!
            so it doesnt really matter if it rocks? as long as it doesnt do any harm when wot, im fine with it...
              Normally this happens when rear mount is torn..
              To troubleshoot with the engine idling, try pressing the thorttle boby linkage slighty aggresive(like jumping form 800rpm to 3000rpm in a instant) n see if the engine sucks down (way down) in the rear..if it does then u have a torn rear mount..for manual trans.
                front and rear motor mounts go check it out
