Upper Control Arms
    Upper Control Arms
    Could someone tell me if the nuts that hold the UCA pivot points in place are reusable? If I loosen them to remove the UCA will I have to replace those locking nuts?
    uca
    no you dont you can reuse them
      Thanks CB9PR. It was much easier to get the UCA out by dropping the pivot points out from the engine bay. Nice to know I wouldn't have to get new nuts. I had the UCA out in a couple of moments, mostly because I couldn't use anything but a box wrench.
      Then I was able to get the upper ball joint out which was my real objective. Attached is how I did it. I used the smallest adapter from my Harbor Freight 3-in-1 ball joint press and whacked it with a 4lb maul.
