JDM H23 Vtec
    JDM H23 Vtec
    Only wanna know How much HP and torque a JDM h23 DOHC Vtec as !!! I saw one for sale near my house and he ask 800$ 150 000 KM
    190-170-175-190 compression
    I've check on Hondatech and Saw:
    2.3 Liter DOHC VTEC Engine Hydraulic Operated Tranny.
    220hp/163tq/11.0 Compression Ratio.
    8000 RPM Redline.
    5500 RPM Vtec Engagement.
    P5P Ecu.
    Can this be... and if yes is it a straight swap !!!!
    Is there a way to difference JDM and USDM h23 on a pic ?!?!
    THX
    This has been discussed at length in the swaps forum.
    The H23 VTEC is an OBD2 motor, so there would be additional wiring necessary. It makes decent power, as you can see.... though I've heard it only makes 200hp. I've never seen one in person to compare. The swap should be similar to an OBD2 H22 swap (euro r or type s)
    They were automatic only, so there is no corresponding manual transmission.
    I have heard two descriptions of the head. First, everyone was saying that it was simply an H22 head. More recently, I have heard that it is a totally different head, and only has VTEC on the intake cam (much like the SOHC F series engines).
    It came from the 6th gen wagon and sedan, and it is not a performance motor. The H22 is a better choice, unless you just want to be different!
    The one really cool thing is that the cars that it came from were AWD. That is something we have yet to figure out how to install in our cars! I'd deal with an automatic AWD cb7!
      So it would be hard to swap and gotta be automatic tranny :\
      Here a pic of the engine... Maybe the guy don't know what he tell and it's not a H23 :P
      because for 800$ it's good compare to 2500$ that a shop ask me here :\
        For $800, it's a good deal... if the motor is good! Go look at it and check the stamp to the left of the header. If it says H23A, then it's probably the real deal.
        The swap wouldn't be TOO difficult. Anyone here with an OBD2 swap could help with the wiring, and it's probably already on here somehwere.
        It wouldn't HAVE to be automatic... it makes no difference to the motor if it's auto or not. However, there are no manual transmissions with the ideal gearing for that particular powerband. The H22 transmission will probably be the best choice, though the F22 trans will work.
        The possibility of VTEC being intake-only bothers me. I don't know for sure if that's true or not.
        Finally, the biggest concern would be the ECU. I'm assuming you wouldn't get the proper ECU for that motor, so you'd need to run an H22's P13 most likely... that won't make it run the way it should run, and you could have rich or lean spots (rich is better than lean to an extent) A chipped P28 is what you'd really need, but you'd have to find someone to tune it for you.
          like what deev said..
          but not all CH9 accords (6th gen JDM wags) were AWD...
          and they came in tiptronic form only..
          and im still doing some research on the H23 VTEC head..
          well, if u dare to be different..
          it wud be great if u got the whole front cut.. wiring loom, front arms (5lugs)..
          woot!
          cheers
          Click sig to view MR thread
          Links to other rides:
          Honda Accord Euro-R
          Honda Odyssey Absolute
          Honda City I-DSi
          Honda Stream
            I want the whole front and rear cut So I can make my wife's 6th gen AWD with 200hp (or more)
            And yeah, they aren't ALL AWD, but all the H23 VTEC ones were, weren't they?
              H23 VTEC head is similar to the H22 Head. I thought H23 had blue valve covers....It could be he just threw an h22a head on an h23a1 block? I dunno cant really tell with the picture.
                that wud be wicked
                the CH9 SiR was 2wd, the CL2 SiR was 4wd
                the H23 VTEC is also a peakier engine,with peak torque of 220Nm arriving at a high 5300rpm
                and i forgot to mention, the 4wd variant lost another 10PS, so the CL2 only had 190PS..
                poooo.. :P
                Honda Accord Euro-R
                Honda City I-DSi
                Honda Stream
                  yeah, the H23 had blue valve covers
                  the one in the pic is blue,its just dusty..
                  i think..
                  Honda Accord Euro-R
                  Honda City I-DSi
                  Honda Stream
