all right, well a few friends and i were talking about our cars and what we could do to get even more power, and i suggested the i should hook the ac up to my intake. well i have a few questions and concerns. well to start off, has anyone even tried it, ya i know it would be alot of fabrication, but i have a friend that has a dyno in his shop that i can use if i even do it. any ways lets get started.... ive been thinking it is possible, but ive been looking around, and before u think im dumb or anything, i usually dont get to do research until i get off work.. i work 18hrs a day, 2 jobs.... ya tell me about it so i usually fall asleep.. well anyways, i was woundering what the dew point is on our engines, so that i wont be producing moisture in my cylinders, fouling out pluggs, ect.... i was just woundering. thanks for ur help
ac questions and experiment
Would the power gains of the cold air generated by the AC be greater than the parasitic losses caused by running the AC compressor?
At normal operating temperatures, I don't believe any moisture could form in the cylinders... it's way too hot. Any minimal moisture formed would serve to suppress detonation anyway. AC is usually devoid of moisture anyway, which is why it works to defog the windows.
I don't think it would work, seeing as the drag of the compressor would probably be greater than the benefit of the cold air... but it's worth a try! If you have access to a dyno, you can find out if it works for real, so it's definitley worth finding out
This was discussed a long time ago on another board. Hondatech or g2ic. It was concluded that it didn't work and then someone tried it and it didn't make a bit of difference.
Not to discourage you though, I love seeing new ideas being tested.Post count is not = to experience rating
F22B DOHC
Just take the compressor off and get a bypass belt then. youll see about a 10 hp gain. correct me if im wrong.Wife: "Why do you get G power platinum and i only get V power?"
Me:"Cause i have the high compression 93 octane only H22 and you have the bullet proof F22."
Wife:........................"But yours are prettier"
Wife:Baby, not everybody wants to do the 93 conversion"
Me:YES THEY DO, THEY JUST DON'T KNOW IT YET.
Originally posted by 12gageJust take the compressor off and get a bypass belt then. youll see about a 10 hp gain. correct me if im wrong.
the effect a/c has on engines is overrated quite a bit too. they don't cause as much loss as what people think (5hp is about average) and they don't cause excess fuel consumption (rare that it will change the average 1mpg per tank) and it's really a waste to pull all the stuff off when you're a ricer wannabe.....and on the 7th day, deevergote rested and called his mom.
Originally posted by sarecho7280the effect a/c has on engines is overrated quite a bit too. they don't cause as much loss as what people think (5hp is about average) and they don't cause excess fuel consumption (rare that it will change the average 1mpg per tank) and it's really a waste to pull all the stuff off when you're a ricer wannabe.
well guys what i was thinking, is more like a supercharger.... i want to hook it straight to the throttle body since the ac has a filter already on it, i was thinking that it would more or less force more air into the cylinders, and not only more air, but colder air, we all know our ac blows freezing cold anyways, plus i need a new experiment, im kida running out of things to do to my car, plus if by any chance something does mess up, i need a rebulid anyways. but thanks for the imput guys, keep it coming.....
Originally posted by deevergoteWould the power gains of the cold air generated by the AC be greater than the parasitic losses caused by running the AC compressor?
But you are right. this will never work. it is a waste of time.
The a/c would never have enough pressure to cause any boost. Just SLIGHTLY cooler air. Even if you made power, I doubt it would be enough to warrant the time and money you putinto it
It would be easier to just get one of those CO2 collars that go on your intake.Post count is not = to experience rating
F22B DOHC
Originally posted by yellaboibut a supercharger is actually forcing air into the chamber.
Y not route an intake pipe to the front of the bumper, thats what I setup....ram-air...
It works great and I seem to need less throttle on the highway now.DEVOTE
FS: Lokuputha's Stuff
