plenums
    plenums
    okay, so i recently bought an intake manifold off an a6 to install on to my a1, would any other more performance oriented plenums work/fit with this manifold, like off an h22 or 23???
    ZING!
    MY RIDE
    -=HondaSpace=-
    This has already been covered.
    Check the DIY forum.
      And yes. H22 and H23 plenums are the same, and will work. You'll need the proper throttle body as well.
        k, i found a whole intake manifold assembly minus the throttle body for the 2.3ltr non vtec prelude motor, would the plenum be the same off that as it would be on the vtec motor, and would the gains from this make any of this work even be worth doing???
        ZING!
        MY RIDE
        -=HondaSpace=-
          As said in many many threads in the past week alone... yes. The H23 intake manifold will produce the best gains on an F22 of any stock manifold. The entire thing, unlike the H22 manifold, will bolt right up to the F22.
            h23 or h22 plenum or type-s. i know the runners have to be h23/f22b/or f22a6. what about aftermarkets. does it matter about the t/b?
