Annoying Window Problem
    Ok so this started when i got my cb, my passenger window would go down but would not come back up, even using both of the switches nothing just down no up. I took it to some guy and payed 40 to get it fixed, worked perfect for like 3 weeks and it's back to the same but not as severe. The window goes down perfectly but it goes back up when it wants to or after like 40 tries on the switch. what could this be?, getting annoying, if its the switch can i buy like one of the 3 prong switches and use that? Or is the motor to blame? Thanks for the help in advance.
    THE BIRTH OF A BEAST
    Do you hear the motor clicking? Is it trying to go up but just cant? Or does nothing happen at all?
    could be switch, motor, regulator, window channel.
    if it goes down but no up i wouldn't think motor
    the window channel on my drivers side needs replaced and it has a problem going up sometimes. spray some wd40 in the chanel and see if it helps
    Post count is not = to experience rating
    F22B DOHC
      most likely its the motor followed by the regulator.
      Id replace them both at once. ebay got em for 40
        Yeah i can hear the motor trying but nothing, i have to flick the switch up and down and after about 40 tries it goes up,lol. Ebay? Ok im check that out.
          Found the problem! i decided to take apart the switch and viola! The little prongs and contacts where filthy, i decided to cleand them out and it works like a charm. Thanks for the suggestions guys.
