engine bogs down @3500 rpm
    so i just recently picked up a 92 ex and i finally got all the suspension problems worked out but the car wont rev past 3.5k in any gear and completely shut down at a traffic light on me. it started up after about 5 minutes and after i took the key out and put it back in.
    im thinking it either the ecu or the distributor.
    any one have any suggestions?
    1.)Do you have any engine codes?
    2.)Does it happen when you first start up or later on while you are driving?
      it happens alll the time and yes there is a code but i have to check to see which code it is throwing.
        u guys need to resolder ur mainrelay or get a new one
          when it gets hot out the old solder will sometimes come apart this use to happen 2 me all time time in my first accord b4 i resolderd them their is a diy on here about it ill c if i can find a link and post it
          http://www.cb7tuner.com/vbb/showthre...ght=main+relay
            Let me guess also you are burning a ton of gas? Check your code, it could be a alot of things.
            I had that problem recently with one of my cars, Wouldnt rev past 3500 rpm, turned out I had a CEL and the cel was code 16. Fuel injector was the problem, I changed them all to a good set and car ran great after that.
              yeah true or a injector resistor box going bad
                Actually I have yet to see an injector box go bad, I seen alot of wierd problems but they rarely go bad to my knowledge.
                  yeah .... ii accidentily fried mine by hooking up the battery backwards lol stuipd me back when i didnt kno shit had to replace mine
                    i will definatly try this.
                    Thanks
                      i have to check the code for sure. i know i saw a thread on here how to check the codes....
                      im a civic guy! they just have a light on the ecu that lights up but i think accords are different!
                        CEL codes
                        http://www.cb7tuner.com/vbb/showthread.php?t=21259
                          awesome link
                          I will keep you guys posted!
                          Thanks
                            another common cause is the ground off of the thermostat housing, if that is loose or broken the car will run in "limp mode". good luck!
                            if ur 555 then im 666
                              It your car gives a code 1 then it most likely an O2 senor.......
