quick question
    quick question
    I have NGK blue I guess 8 mm's.
    Should I throw them on or wait til I get the NGK plugs. I have bosch racing plugs right now because of my old setup. and I got the wires in the mail already and I don't think a good month til I get the plugs.
    No longer have a cb7.
    V6 POOOWAAAA
    lol, a buick.
    It shouldn't matter. you can put them on now or later. it's up to you.
      Anyone else?
      so mixing them is ok? I would figure it's ok it only holds the spark but with thicker wires IDK if the plugs like have to match or somethin idk.
      V6 POOOWAAAA
      lol, a buick.
        Originally posted by 407accord
        Anyone else?
        no, it doesn't matter at all and the difference isn't nearly as big as you're making it out to be....
        it's like getting 1 penny too much back in change.....you won't burn in hell for doing it
          ok good.
          Anything I should know before I did this procedure?
          Just take the ones off, put the new ones on? No sparks or anything?
          I just took the first one off and on the dizzy side or coil or w.e it is, there was like a little line of electric when i had disconnected it.
          V6 POOOWAAAA
          lol, a buick.
            Ok, I have a problem.
            On the where you connect it to the spark plug. THe rubber around the top of it is not going around the opening. Are all NGK's like this?
            Also my number 1 is not as long as the bosch one's. which I guess is a company matter but it still makes it, but the rubber is not fitting around the top like it's too small.
            V6 POOOWAAAA
            lol, a buick.
              It should fit...make sure the center metal deal is lining up instead of forcing it on. Mine NGK set fit just fine.
                What? center medal deal? It's not going, I've tried everything. If this guy sold me a wrong set or something....
                V6 POOOWAAAA
                lol, a buick.
                  It's just sitting on the rim of the metal, the rubber lip is not going around.
                  Wonderful. Well I'm putting my old ones back on until someone can answer.
                  I will try to get pictures.
                  V6 POOOWAAAA
                  lol, a buick.
                    Anybody?
                    V6 POOOWAAAA
                    lol, a buick.
                      You may have gotten a set for another car.
                        Yea or that. There should be a part number on the box. Type it into google and see what it pops up with should be what application it for.
                          Wrong set. I have NGK blues and they fit perfectly.
                          1996 Honda Civic LX 2009-2012
                          2012 Kia Optima LX 2012-2013
                            Look on the NGK plug wire box. Part number should be 9428.
                              yeah to me it really sounds like you got the wrong wires.like everyone else says check the part number.
                              Mr.Phil: "FitMoHoesInMyFoDO"
                              Young jeezy:If you ain't talking about money then you ain't talkin bout Shit.
