OK i just finished doing a auto to 5 speed swap and everything went good until it was time to put in the driver side axle. Everything is finished the wiring the shift cables everything is plug up and ready to go. Then it happen i put the axle in and tried to put the spindal back together and it seems the axle is to long i dont know if the axle is bad or what. I took the axle out of the same 5 speed car that i took everythings else off of and the axle was fine on that car. Can any body steer me in the right direction?
5 speed conversion problems
what setup are you using for the transmission mount?
so youre having axle alignment issues and you havent even bolted the motor mounts in yet? i could only assuming thats why youre having issues...
you need to either cut and weld a new transmission mount or jerryrig a prelude transmission mount to fit... if you didnt do either of those, your motor is WAY crooked and will not line up in the slightest...
do not worry about the axles until the motor is lined up and bolted in perfectly straight.
