As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
brake light problem
    brake light problem
    for some reason my brake light stays on. it usually suppose to go off after i release the e-brake but even when i do release it it still stays on? what do u think the problem is?
    The sensor for that light is right underneath the e-brake handle.
    You could take a look at it by taking off the center console.
    92-93 have 3 screws on each side and a front part, under the radio back to the e-brake and a second part e-brake back. These two parts are connected with 3 screws in the middle.
    I believe 90-91 is a little different, but same ideaish.
    Just take off the center console and see if something is stuck holding the little button up that the e-brake usually holds down.
    Click for my ride thread.
