tranny cost
    tranny cost
    how much do you guys think a new tranny will cost 4 my cb7?
    its about 2 blow and i need to replace it but dont know how much itll cost and do you guys know were i could find a good 1 from?
    DONT SWEAT THE TECHNIQUE
    at least 250. wat is it doin that u think its gonan blow?
      like when i take off quick it wont change gears tilllike 5 or 6 thousand rpm and when it does change gears itll throw your head back and when i make turns and press on the gas the rpm will go way up without changing gears.
      do you guys think that its ready to blow?
        http://cgi.ebay.com/ebaymotors/1990-...mZ200131237607
        I have no idea BUDDY tahts y i was askin. that link shows trannys for the accord.
          I've bought mine for € 250,-. That was for the tranny, pedals, clutch, shiftcables and gearframe, etc.
          Your car is faster, I'm the better driver
          Greetz Erwin
          My last ride
          Shakes and Fidget - The Game
            youcangetthematajunkyardorfromsomeonethatjustswapp edtheirmotororanothertransmissionisoldanentiref22a 1withthetransmissionattachedfor50dollarswheniswapp edsoyoucandefinitelyfindthemcheapifyouwerentsofara wayidsellyoutheoneihaveinmysheditworksperfectly.
              I dont think he wants one from the YARD. Plus the YARD doesnt give u a warrenty
                where do you live?
                  look on LOCATION on his SIG
                  Originally posted by birdmanCB7
                  where do you live?
                    My car was doin the same exact thing so i had my trans flud chaanged and its better.....BUT i discovered even b4 i changed th fluid that my trans is leaking fluid and found out that its the gaskets that need to be replace. so check to see if its leaking anything
                      x2 also heres a SIMPLE DIY for tranny fluid change!
                      http://www.cb7tuner.com/vbb/showthre...y+fluid+change
                        yeah actually my car is leaking.. so you think i should change the gaskets and change the transmission fluid
                          2 change the gaskets/seals the tranny has to b apart from the motor.
                          but change it asap. that DIY is EASY to understand any questions send me a PM. I jus did this 2 weeks ago.
                            is it easy to change the gaskets
                            is there a diy on changing gaskets?
                              i havent seen 1. but u gotta kno somew knowledge of removin the tranny. but i havent seen a diy for that.
