i recently downloaded CROME tuning software but how do i actually use it, is there some kind of interface cables that connect from my laptop to my ecu, can it be used with the stock ecu, or does my ecu have to be chipped to run it with it any help is appreciated
How to use CROME
right now i cant do anything on pgmfi.org i cant sign in, but i looked at the links above and 3 of them were how to chip your ecu, ok got that, and the other was how moates, dont care about all that, i just want to know what cables do i need to connect my computer to ecu, or if thats even how it works
The information is in those links. Plugging your ECU (chipped or not) into your laptop will not turn it into a standalone tuning system. You need to burn chips, and to make things easier, run an emulator such as the Ostrich (both the chip burners and the Ostrich are Moates products, I believe) So yes... you DO need to read that.
Read. Don't touch your ECU before you KNOW what you are doing. If you screw up tuning your ECU, your car isn't just going to throw a CEL... it'll probably throw a rod.
Originally posted by zigg_1311ah, nevermind i found it, i need and datalogging cable and serial, thats all i wanted to know
