I have a 92 lx accord 4dr auto I just bought a parts car that has a f22a6 motor h2u5 trans and a pt6 ecu. I bought it just for the trans swap but after doing a little research I might be inclined to swap out the intake manifold as well. I know the a6 mani has secondaries and require vacuum to operate and I am assuming it also requires some sort of power source but after all the research I did I could not find anything about wiring info. I would also like to know if someone could tell me the difference between the f22a1 and the f22a6 like internal wise.
Trying to breathe alittle better
Why dont you just swap over the whole motor...Whats wrong with it.
Not to sure of the condition of it. I was told it had about 130,000 on it but dont know what the compreesion is. Also one of the ears that hold the distributor on the head is cracked. It looks in good shape but looks can be decieving. The only thing I can say is I can turn the crank by hand.I need a 14b or 16g turbo!
Cams, plenum, exhaust manifold, ecu.
I am going to be swappin the cam, ecu, and intake manifold from an f22a6 to my f22a1 soon and was wondering are the injectors form the a6 manifold the same as the ones from the a1 manifold and also the ecu i have is a pt6-a11 I am sure it is for a 5-speed and my car is a automatic but I am also going to do the trans swap. Would I still be able to drive it with the pt6 ecu until I swap the transmission.I need a 14b or 16g turbo!
