I read here somewhere that the A4 header was as good, if not better than most of the aftermarket brands...Megan, DC etc.. I cant find that thread now, though. Is the A4 better? If so should i get the downpipe as well, or is it the same as my A6 pipe?
A4 header Vs. Aftermarket
yea they are 14's if I can remember correctly. PB blaster works ok.Originally posted by Leungyeah get it. don't forget to bring some WD40 or something that will help break down the rust. i didn't bring any with me the other day so just two bolts were keeping me from going home with it. it's the two big ones that hold it to the flex pipe.
I used a long breaker bar for those.
on a side note- the yards over here always CUT the damn Cat off, insead of unbolting it, making the downpipe useless, or at least thats what I see it as.
you're gonna need the downpipe/flexpipe, unless you have a F22A6.
Originally posted by kc8enb07does it come w/ jdm trash? they better throw away gold in it
i wish i had enough room to get a breaker bar into there but with the car still having the radiator in it still , i might have to resort to bringing my much stronger friend to bust those bolts loose.
well i was going to do the whole exhaust anyways so i was going to buy a whole new downpipe all the way back. i figured it out in my head that if i was going to do that anyways, why not get something that makes my car a little more peppy header wise that is...
i've seen the stainless steel header and downpipe combo on ebay go for like 70 bucks shipped but i prefer OEM especially if it's an option that i could go with.
the only kink in my plan is i'll need a new o2 sensor unless i can get an extension for my A1's o2 sensor.
Originally posted by Cb7GHOSTyea they are 14's if I can remember correctly. PB blaster works ok.
I do have the A6, i guess that means i can use my downpipe
. The prelude i got my h23 head/IM/TB off of let me take the Exhaust manifold off with a 3/8 ratchet, everything came off that car so easy i forgot i lived in the rustbelt.
so what is an A6 header a 4-1? and I thought it was better than the a1 and a4? or is that the intake manifold? im confused. Right now i've got a dc sport 421 but i remember my old header was much heavier than my ceramic one i currently have. So, if I put an A4 header on, wont it have an o2 sensor attachment? so then I'll have 2 o2 sensors? will that work?
OK, the A6 header is 4-2-1 CAST design, it isnt shaped the same as the A4. bottomline, A4 is the best of all 3 headers.Originally posted by Losiracer2so what is an A6 header a 4-1? and I thought it was better than the a1 and a4? or is that the intake manifold? im confused. Right now i've got a dc sport 421 but i remember my old header was much heavier than my ceramic one i currently have. So, if I put an A4 header on, wont it have an o2 sensor attachment? so then I'll have 2 o2 sensors? will that work?
DONT put the upper half of the A4 header on your DC sports down pipe thinking you'll get gains or you'll be wasting your time. UNLESS youre trying to get by smog. I'm not sure it would even fit...My DC header doesnt have a carb stamp - I was told they were all carb legal; maybe he just wanted me to buy it.
there are so many a4s around here in the yards but all the flex pipes are either cut off at the cat or just f'd up it sux cause i can get one for like 10 bux but they are all skrewed
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
