Park Light
    Park Light
    Ok I have a 92 honda accord ex have noticed neither of my park lights come on and the two front corner lights. All the other light work tail light and brake light all light in car work also. Checked the fuses pulled on bulb and replaced with new one that one still did not work if on bulb is out will it keep the others from coming on.
    Your bumper lights (on my car at least) only come on as a turn signal. Your corners would be the only lights that stay lit when parking lights are on.
    You've replaced all 4 bulbs in the corner lights and the 2 bumpers?
    MRT(vvv) --Stock CB7 Enthusiast #1--
    Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
    i am with the dumb. i cannot brain.
      Parking lights
      Your right the two on the bumper are blinkers they work the two side ones don't having a hard time getting to the bulbs any easy way to get to them and you say there are four bulbs .Will try whe it quits raining.
        parking lights
        Thanks for replying 93accordfreak went after it quit raining and figured out how to get the lights out to replace the bulb all the bulbs were blowned. replaced them and all work now thanks again.
          i kinda had the same situation....but it was the front corner lights then the taillight's break/parking lights..they didnt work at all...then i found out...tht i 4got to put the break relay frm my old taillights to my new taillights...then when i put the relays back in they work'd almost perfectly fine...it jus my corner lights didnt work when i signal...but its jus a burned bulb...oh yeah and when i put the relays back in...i found out...all the bulbs for the taillights n corner were all burned out...so i had to replace most of em i jus 4got the corners
          "You never really learn to swear until you learn to drive."
            i put LEDs in mine since i have those clear corners so i needed something to light up amber, was quite expensive about 20bucks but they'll never blow out again. last time i tried taking the corner light out, it broke so thats why i did that.
