CEL stays solid when jumper connected??!!
    92 lx, sometimes when i try to start my car the CEL comes on and stays on for a long time. i try and get a code but the CEL doesnt blink it stays solid, not the usual long blink then short i meen it stays solid. is there a code like that or is something wrong. i had to wait like 2 hours the other day and i was almost late getting back to work from lunch because of it. if anyone has any clue or suggestions please let me know.
    Hey yo uhhhhhh fry man!!!!
    http://www.cb7tuner.com/vbb/showthre...&highlight=cel
    check that out.
    Originally posted by jboyce
    i f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
      thanks but i already knew that. did you even read the post. now if you were suggesting i look at it to see if there is a code like that thanks i really appreciate. any one else?
        solid CEL usually means bad ECU. Does your car rev past 4k?
          yeah. i actually have no fourth gear so im running 4.5k at 70mph i cant help it i try not to go that fast but i have to on the way home from work and to work because i have to take a main highway. fourth and reverse are out so i know i need a new tranny. bad ecu huh? how can i be sure other than taking it apart and checking for burns and etc. thanks alot man seriously.
            The easiest way to find out is to swap in a different ecu.
            It's not hard. Pull back carpet, take off the bolts holding down the back plate, and unplug the ecu.
              are the main ecu's anything like the TCM's do the numbers need to match?
                They don't need to completely match. As long as its from an accord. The three middle characters the ones you need to look for.
                PT3-f22a1/a4 ecu
                PT6-f22a6 ecu
                P12-f22a1 from prelude
                All those would work without a problem.
