Trans swap
    Trans swap
    I am getting ready to pull the manual trans out of the parts car I have to do the manual swap on my other cb7 and was wondering if there is anything I should check/replace while the trans is out. I mean I know the obvious like the seals but is there anything internal that should be replaced like bearings thats alot easier to do now while its out.
    I need a 14b or 16g turbo!
    clutch since u ill have it out might as well put in a better clutch kit since i am pretty sure there is a part of the clutch thats recommended 2 b changed anyways.
      a flywheel with less weight
      Your car is faster, I'm the better driver
      Greetz Erwin
      My last ride
      Shakes and Fidget - The Game
        also replace the rear main seal on your car before you put the tranny back on....ull have to remove the flywheel for that
        Hold On Not Done Accelerating
        Had One Never Did Again
          Yeah the clutch is an act it was already in the car so I will inspect it I will replace the throw out bearing and the external seals on the trans and also the rear main seal on the block. How about internal wise on the trans are there any parts that are prone to be damaged or worn that I can repair or replace
            Replace:
            1. Internal tranny seal
            2. Rear Main
            3. Axle seal if necessary
            4. Resurface flywheel (or get a new one)
            5. Make sure clutch is good.
              Originally posted by NAiL05
              Replace:
              2. Rear Main
              When you say internal tranny seal are you referring to the input shaft on the tranny the one that is inside the bellhousing
                Input shaft and main seal.
