I purchased a parts car and it has slotted and drilled rotors so I was just going to swap out spindles so I didnt have to separate the rotors and I noticed the upper ball joints were adjustable. Are these better than your normal camber kits? I assume it is for when you lower your car you can adjust camber in or out. I am going to replace the ball joints before I put them on my daily driver and if I can use these adjustable upper ball joints it will save me about 60 bucks plus when I lower it I will be able to adjust the camber.
Adjustable ball joints
