I had found a thread about placing a diode or resistor in the 02 sensor circuit at one point in time. I cannot locate it anymore. Anyone have a clue about this mode? Appears that these pre-heated sensor's fail commonly. Just looking to fool the ECU. Thanks for the help.
02 sensor, fooling it?
i wouldent do that... you can "fool" the ecu, but lean is lean, and the ecu will only dump so much fuel... ill tell you: youll be the first person to know when you screwed up, first itll bog, then itll smoke, then itll stop running, and when you try to pull the head off, and find it warped so bad you cant get the bolts out, youll be wishing it was only a bosch 4-wire pre-heated oxygen sensor you had to buy (dont listen to the honda myths about bosch and honda not going together) and just for shits and giggles, check to see if theres oil in the connector of the o2 senserme... talking to service-writers
the look on their face
moments after that conversation
there! i know i feel better
