electrical prob
    electrical prob
    what up guys, i was wondering if anybody had the
    SMALL LIGHT FUSE diagram
    is a under hood fuse
    is that since yesterday the motha f****
    keeps blowing
    i put another one and it lasts for 10 min an blapppp bye bye fuse
    does anybody know what else appar from the rear lights, and incar lights????
    Just do what PR CB7 said.
    bumpppp?????
    anybbody???
      its a short
      its a short to ground.... it shouldent keep blowing like that, if you have ANY after market electrical devices in there, you somhow tied into that already crazy sensitive circut.... but check your rear-lights to make sure all the connectors are in good shape anyway... im sorry i dont have a wiring diagram for you... check mitchual, or haynes
      me... talking to service-writers
      the look on their face
      moments after that conversation
      there! i know i feel better
        Hey do know why the ODO doesn't seem to work but all of the other gages work just fine. I was just wondering because doesn't move at all.
          has for the ODO question
          go to a junk yard and take the odo form a nother car and swap it
          and i mean switching the MPH no the whole tach
          that worked for me
          as for tmy prob
          is that i put the 95 accord rear bumper lights in and tied them to the stop lights
          whatcha think
            whatcha think
            its a possibility that theres not enough resistiance in the lights you used, (are the bulbs the same?) but id re-check all my connections just to make sure, it really sounds like a short
              alright thanks man for the advice.
                can u guys understand this?
                keeps blowing
                i must be too old for this...cuz i dunno what the hell this thread says...
                what's he mean by "small light fuse?"
                YEP. I AM Canadian.
                1990 Accord EX 220,000 KM. Essentially stock with 15" alloys and chin spoiler added. K&N filter and Bosch plugs. ICE COLD A/C which I love!
                1992 white EX 4 dr, 5 spd. (602,000 Kms and I JUST RETIRED IT. SO SAD!) DEC 9TH, 2005 - MAY 31, 2012. I added 229,000 kms to it. Great car!
                  alright, it's for the odo problem I can get the cluster out but there is a problem on the other side of the steering wheel by the drivers side door i can get it off on that side. is there some special way to take it out?
                    i was just thinking b/c i do that ya know!! your odometer runs off of this *** little steper motor (i know, iv taken these things apart manny times, manny moons ago) and if this *** little steper motors not working, im more then willing to bet it didnt "just blow" or "just stop working" so then, my question to you is.... has it ever worked? have you ever taken the cluster out EVER, or has a friend? the reason i ask... is beacuse this preticular cluster (4th gen. accords) have a really stupid setup going for them, each of those tiny little gold + type screws back there hold a component (or load device) in place... ie, your speedo, tach, odometer steper motor... now, if their not re-installed ever so gently and carfully, youll notice, a component on the cluster will not work... the reason, is that those little gold screws actully compleat a circut, and the tiny thread-like wires (uninsulated) that lead up to the base of where the screw goes in, break so easy, youd never even know unless you looked...
                      I got my ODO fixed I just took it out and clean the gears and re-wired the plug-ins so it's working just fine.
                        the fuse is an under hood fuse
                        that says
                        SMALL LIGHT
                        look and u'll find it
                        i wanna know what it control
                        be cause yesterday i found an exposed wire which i thought was the one
                        and it workd
                        but i was racing today and
                        taking a sharp turn
                        BAMMMMMMMMMMM
                        blew the freaking fuse
                        and the funny thing is that i know i the freaking wiring
                        but WHEREEEEEEEEEEEEEEEEE
                        AAAAAAAAAAAGGGGHHHHHHHH
                          man this is drivin me crazy
                          yesterday
                          i did the wiring like GOD wants it to be done
                          i toke the same gauge wire, and wired them with no breaks, a direct cable to the brake lights
                          and it worked fine i thought i had it fixed
                          SPYCHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
                          blew again
                          i even soder it
                          could some one could get me the LINK
                          of the DIY of the cd5 bumperlights
                          so i can PM the writer of it
                          thanks
                            yesterday
                            blew again
                            i even soder it
                            thanks
                            i have that same problem but my fuse only goes out if i hit a bump real hard or if water gets into my wires. i wired my bottom lights to the corners and when it rained the water would get down in between the tape and it would blow. so i waited till it dried then put the fuse back in and its been good. check the wires in your corners and the light on the roof inside
                              u sure its the right Amp size fuse??? do u hAVE AN alarm on it?? cause sometimes the alarm wires foir the light makes them burn out if its not installed right...
                              turn the key,Clutch-Gear-Gas ..Gone.... R.B.
