As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
02 sensor problems, please help....
    I have a problem, code 41. 02 heater circuit. I have replaced the 02 sensor and the code will not go away. What am I missing. I cleared the ECU as per the DIY in another thread. Thanks for the help,
    David
    what brand oxygen sensor did you replace it with?
    Members Ride
      A Bosch was all that was available. Check the previous post. I am getting four long blinks. I cannot find a code 40 anywhere?
        i did read, thus why i posted. you first post code 41 which is indeed what you stated. then you go and say code 40
        and you are sure its just 4 long blinks and not one short one?
        is it the universal one that you have to splice in? or the "oem"
        the problem lies within the o2 sensor, i am speaking from experience, if you go with a ntk or denso o2 you should be good to go
        Members Ride
          my bad, I had a code 41 before I changed the sensor. The light was still on after replacing it and clearing the ECU. I assumed the 41 was still there. I just went out and rechecked it. 4 long blinks. No short ones. So is this a code 1 and what is that?
            so its 4 longs blinks continually or is there a pause between them?
            Members Ride
              The blink and the pause appear to to last the same duration. So blink, pause, etc. It cycles 4 times.
                hmm, can you take a small vid of it. to me it seems to be code one
                Members Ride
                  Sorry no vid available. After thinking through the process, it must be a code one. Are the Bosch sensor's that bad? I am trying to sell the car and that is all that was available on hand. I could special order a different brand. This is holding up the sale of the car. What about the connectors up by the strut tower on the pass side of the car? Any known problems with them?
                    Oem replacement sensor. No splicing.
                      grab one from a junkyard if you can just for the sale
                      and you reset the ecu by removing the 7.5 fuse? how long did you have it out for?
                      Members Ride
                        I have let it sit for at least 10 minutes each time. I have thought about the wrecking yard swap before. BTW, thanks for the help.
                        David
                          your welcome. i would suggest just picking one up from a junkyard, and just throwing it in there since you are selling anyway
                          disconnect the negative battery cable and see if that erase it. then drive it around and see if the code comes back
                          Members Ride
                            I would suggest to clear the code, test drive it, and if it does not recode, then it is fine. but if it does recode, then you may have another problem, such as fuel supply system.
                              to think of it, it may be a code 4.....tdc sensor crank sensor code. possible bad distr.
