has anybody put a h22 head on a cb7
head swap
yes a few people. USE THE SEARCH
On it, in it, in the trunk... I put an H22 head on a shelf in my basement! The best way to put an H22 head in a CB7 is to do it while attached to an H22 block.
Search for "frankenstein" and you'll probably find a few threads about it in the swaps forum.
The bottom line is: why put a head that benefits from a 7500 RPM redline and 10.0:1 compression on a block that's made to rev to 6500 and has 8.8:1 compression? The H22 in stock form makes peak power above the stock F22A redline. The F22A block CAN rev that high, but I wouldn't trust an old one to do so.
Just buy an H22.
well what do you know.. this is where that leads me !!! hehehe.. ok did some research and i know how to do the swap and all.. but if it was done and all new mains and rod bearings installed.. would the motor hold up ??? i don't have the funds to get a h22 block and would like to do this setup since i haven't done one on a f22a block yet...Originally posted by deevergoteSearch for "frankenstein" and you'll probably find a few threads about it in the swaps forum.
sorry to invade this post but i figured i might as well just ask instead of creating a new post !!
At least your questions make sense!
I've been told that the f22 internals CAN take the stress... but I'd still be a bit uneasy about it. The difference in compression will have a considerable impact as well. Either get yourself an H22 bottom end, or get some forged rods and high-compression pistons for the F22 block.
