Tach issue
    Tach issue
    Hello guys,
    My 1993 Accord Ex is having a tach issue. All is well until I hit 4500 rpm. Then it acts as if it is sticking and jumps forward. Any known problems? Thanks.....
    David
    wow thats weired goodluck
    RIP F22A1 welcome F22A4
      just either check the wiring or buy a new tach and test that
        possible igniter.
          Have you done any mods to the cluster? Like a white faced backing or something like that, where you have to remove the needle? It may be something as simple as the needle isn't on all the way..
          If that isn't the case it would be cheapest to buy a cluster from a junkyard or just get an aftermarket tach.. Later
            Thanks guys, no mods done to gauges. I have cleaned the dist connections with electric parts cleaner. Still does it. I dunno?
              Mine did the same thing after i put aftermarket covers on. Just go to the junkyard and get one for like 5 bucks.
                if you can get another distributor and see if it does it because it happened to me and i just had another dizzy and it quit doing it. something to do with igniter or one of the things in the dizzy.. can't think of the name right now.
                Originally posted by Devergote
                A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                  igniter or coil. and make sure the connections inside the dizzy cap are tight. you can test the ignitor and coil however they make have different readings when they get hot.
                    Thanks I will check those things.
