Well, today I found my keys which were lost for about two wks. (I sure thought I had lost them forever). Either way, here's the main problem. My 91 Accord EX won't start at all. Now, before you go and say bad alternator, check the battery, etc. there is something important to mention... It doesn't even get that far!! It alllll starts back @ the ignition switch. I put in the key (and yes, it's the correct one) and it won't engage even to the "I" position. The farthest it gets is about halfway there. I'm in need of some major help right now. Flood me with responses!!
Help Me Start My Car!!
i occasionally have that issue w/mine...i just wiggle the wheel and when its in the right position it usually it starts right up.FBP 99 Acura 2.3 CL 5 spd (mods a plenty) Estoril 98 BMW M3 Sedan(under construction)
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
X3 for the steering wheel lock itll stop you from starting it you gotta turn the wheel twords the ignition as you turn the key
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
thanks for the quick responses so far... it's an AUTO and i'm familiar with the "jiggle the steering wheel" trick. unfortunately, that didn't work either. what else ya got?
p.s. i'll be sure to charge the battery a bit later today. it's been sitting in the garage cause i don't remember any sparks when i hooked it up earlier.Last edited by TeamAccord; 08-15-2007, 05:01 AM.
well, i think it was actually. for some reason there is a piece just near the key hole on the bottom side that reads the key in the ignition (it tells the car to make that annoying chime, "dee dee dee dee") so you won't forget your keys. as much as i've tried to put that back in where they key can go in and go out freely, i haven't been able to do so. i think i'll just leave it out and unscrewed. from there, my key goes in, starts the car and come out smoothly.
p.s. just to customize it anyway, i'm going to get a push button start!!
yea, it's definitely NOT in park. haha, i've done that before but this time, it's not the case.Last edited by TeamAccord; 08-21-2007, 04:07 PM.
nope. i think i got it. just look @ the replies that i've made. thanks!Last edited by TeamAccord; 08-16-2007, 06:08 PM.
