code 10 and 20
    code 10 and 20
    i just got my ecu and the car gave my code 10 and 20. how do i fix this?
    also when i drive the car it does not shift thru any gears, it seems to be staying in one gear, how do ifix this? oh my car is a 92 accord automatic, h22 with f22 tranny
    H22A ACCORD'S RULE!!!!!!
    code 10: IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
    code 20: Electrical Load Detector defective circuit or unplugged / defective sensor
      ok what is the electrical load detector and how do i fix it?
        its basicly a sensor on the tranny that tells the tcu what gear to use.
        how do you fix, put in a 5spd. j/k I not sure how to fix it.
        MR Thread- I brought SEXY back- LOL
        If it jams, force it. If it breaks, it needed replacement anyway.
        Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
          Ummm, You are quite wrong. The Load detector is inside the fuse box. It varies power your alternator puts out to the car.
            code 10 means that you have to lower your car and code 20 means that you need to take some pictures of lol! jk good luck with that
              It helps the ECU hold your idle steady.
              Don't know how to fix it though. sorry
              3 CB's gone....
              1 WK Overland....
              Still miss the CB though......maybe one day.
                so its a somthing in the fuse box.
                and how do i fix my tranny problem, cuz its not shifting when i drive, its like stuck in 3 gear or something?
                  Really, I was so misimformed.
