AC blower motor issue
    ok recently I've been having trouble with my blower motor not working, I believe it's binding but I can't seem to find out why. The first time it stopped I took it to the shop and all they did was take off the bottom intake peice and it started to work again. The second time it happened I took off the cover and searched around in there to see if it was binding or something, but everything I messed with was tight and not causing any problems. Then I checked it out after I put the cover on it and it worked. Now the wierd thing is whenever it stops working now I just hit the bottom cover and it will start working again ... I notice that everytime it stops working is when it's not running, like if the car's off, or if I have the fan turned off. Could it be something with the bearings or is there something I'm not seeing?
    any help is appreciated! Thanks!
    90 LX, 270,XXX miles strong!
    probably worn bearings allowing it to get off center a bit.
    could be some debris in there too, or something else obstructing it
    "As far as the prog references go, we embrace them. However, we would prefer our new moniker, which is a Mulligan stew of progressive rock, Bulgarian folk metal, rock ’n’ roll, ’80s disco and Christian rap that we like to call Munge." (Maynard James Keenan cited in Boston Herald, 2006)
      Ok, ya I was thinking it might be the bearings, but wasn't sure. Anyway can I get those from a place like Autozone or are they alittle more specialized than that?
        well.. you might check the plug for the blower motor.. because there is a contact switch in there that might be going out !! i had that problem before.
        Originally posted by Devergote
        A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
          I'd just replace the blower motor with another used one. You are gonna have to take it out anyway to look at it. Its a pain in the ass to replace but its doable. I replaced one in a 91 last fall. I got one off ebay for like $30
            i had the same problem as you did i could hit the bottom of it and it would start working...finally it just stopped all together so thats...when i went to the junkyard and pulled one from another accord. They charged me like 25 dollars for it. so maybe u could go that route or order it from ebay like verbaltec said
            Accord Hybrid
