Window wont slide into place! [Picture]
    Okay........
    Sorry, the word that got Cut off in the picture is suppose to say "GAP"...
    So the other day when i was winding the window up, the window just came out of its socket. After pulling the door apart, i put the window back into the slits and when i winded the window up, as you can see from the picture. The gap widens.......Is there something i need to adjust to keep the window going back in the correct direction, instead of going out, it needs to sit plush in the gap? Is there something i can adjust?
    I didnt dare wind the window down too much cause the gap widens even larger when u wind it back up..
    Anyone know?
    Thanks
    x2. me 2 man
    MY YOUTUBE Channel Plz Sub for the Support thanks
    ^^^ Click for the Link ^^^
      i dunno what causes it to happen like that, but im having the same thing
      when i wind up the window, i just hold the window in place. no gaps.
      Click sig to view MR thread
      Links to other rides:
      Honda Accord Euro-R
      Honda Odyssey Absolute
      Honda City I-DSi
      Honda Stream
        same prob on both of our cb's, i must have spent about 15 mins just trying to put the window back up, and there still is a little gap left, now i dont use the rear windows, and i cant drive on the freeway with the cb anymore, its wayy too loud, im sure someone around here knows how to fix this tho
          hahaha damn, u guys all got the problem too ey! why didnt u guys say anything, make me have to run out and use the camera and shit. LOL
          the thing is, this is my driver side (RHD) and it shits me cause i cant wind it down too much to go thru mc donalds drive thrus or get parking tickets etc. Once it winds down too much theres a chance it might come out of the socket again. Hecticccccc i reckon theres something you can adjust...just waitin for a professional to hear us out aye!
            when you take the door panel cover off, look at the bottom of the door. through the holes in the door, you should be able to see a metal arm.
            This arm is attached to the motor at one end and a track attached to the window on the other end.
            still with me?
            the track attached to the window should be quite adjustable. you'll have to play around with it to get it back into place.
            i hope you understand and can see what I'm talking about. maybe someone else can explain better.
              still with me?
              Take off door panel
              then look at the middle of the door, You will see some openings and there is one large opening where the door lock is.
              Now right where the door lock is, there is a long arm that runs inside the door. And at the beginning of the arm there is a bolt holding it.
              Loosen the bolt, Push the arm down, Tighten the bolt and send the window up. If it still does it, Go back and re-adjust the arm.
              __
              __0 ---- Thats how the bolt will be, And the lines are
              __ actually on the door.
                woot so glad to hear about this :]
                  okay thanks guys! gotta try this soon
                    now that was good in4.......but what if it stops just a half inch from the top...what would make it do that
                    Only Hard Thing is Keeping it Clean
                    my ride
                      could be a bent regulator arm, thats why mine used to do that, took two ppl to roll that sucka back up, but got my regulator replaced and all is good.
                      ZING!
                      MY RIDE
                      -=HondaSpace=-
                        thanks................i'll pull the door a part monday when i get off
                        my ride
                          Ok....i got one for ya...
                          Im missing the clips from my DS-front window(I need to replace them anyway), so when id roll the window up, id have that 1/4-1/2" gap. I could lose the gap by lowering the window a bit and rolling it back, then down, then up, and just toying with it. For the most part, i didnt worry about it.
                          Anyway, about a week or 2 ago, i was just rolling the window up like normal and i guess i rolled it too long and right as it got to the top, it made this loud "crunk". And up until yesterday, it would roll down fine, but itd get stuck every 8 inches or so, and id have to help it up. Well, now it wont do either. Up or down. I got the panel off, and looked as best i could, but those holes are at the bottom corner of the door and its kinda hard to really see whats going on in there. Im thinking that replacing the regulator might help, but does anyone know of anything else this could be besides the regulator?
                          Originally posted by Jarrett
