So this morning when I drove my car, right away when I started the engine, I noticed that the idling was at 2-2.5 rpm. And yes I checked out the thread on the idling issues aready. But what if its something else? Just a few minutes ago driving on the freeway, my speedometer needle fell down from about 60 mph to 0mhp and then back. It occurred a couple of times and then it stopped about half way home. In the past, I've had the similar issue with my 90 cb7 lx auto, and I replaced the speed sensor; it fix the speedometer problem. Now, is it possible that the high idling issue might be related to the speedometer? Or possibly both of these parts (speed sensor and fast idle valve) are going out.
Need help.
Well, earlier today, I checked it out, and I found that the throttle cable was the problem. The bracket holding onto the cable might of caused the outter cable to get cinked from aging. Therefore, I pulled it from the bracket and loosened up the nut. This dropped the idling from
2500 to 800-1000 rpm. Although, this didn't fix it completely, it helped.
This is Weird
i had a friend the hit a HARD BUMP and his car
was idleing like at 2 - 2.5K RPM
until he like adjusted his idle screw back to normal
never had this
my car idles high and low on neutral
nothing related to your problem i guess
i still haven't fixed mine
im getting to it
Ride: 2002 Lexus IS300
