Brake light Dash
    Brake light Dash
    I know there are alot of posts on the brake light issue ( the light under the picture of the car) Brake lamp out...
    I read under one posting that there is a way to bypass the modules..
    something about black wires...does anyone know hoto do this...
    Thanks
    Sam Gann
    I figured it out.....Service Manual 16-135....
    This tells you how to find the problem....
    I have a 1990 accord ex 2 door...The module on the lift side on the tail light
    is bad...From what I can tell there is a open from the grn/wht wire and the green wire....Th service manual tells you to ground out the grn/wht wire.. on the left side module top wire left side...single wire...and turn ignition on if the brake light in the dash does not come....try grounding out the solid green wire and turn on ignition and see if the light comes on in the dash....if it does than the left module is bad... or there is not continuity to the right module...
    The other test is to ground out the grn/wht wire and turn on the ignition and step on the brake , if dash light stays off the left module is bad or there is no continuity to right module..
    So what I did was attach a wire from left module grn/wht to ground...now the brake light bulb stays off....I belive the module is showwing a open on that wire which tells the brake light to turn on...if you ground that open to complete the circuit than the light goes out...
    Do this at your own risk...I have not had a problem yet I drove car for about 30 miles today and seems to be fine......The best thing to do would be too replace module....but funds are low...
    Sam Gann
