ok, so my abs light went on about 2 mos ago and it has not turned off..... i dont think the abs function of the breaks are working...since a few short quick stops didnt cause the breaks to pump under my foot.... regular breaks work fine and were actually replaced some 3,000 miles ago and have been fine except for this abs light issue, just some 400mi ago...
however, if it is very humid out, the abs light stays off and the abs is so sensitive that even in regular driving, when i hit the break, the abs immediately kicks in.... i also hear a strange clicking sound coming from what seems to be the glove compartment, just before the abs kicks in....
i've read quite a few posts in the forums regarding pulling the codes, but i'm not sure what that means..... (by the way, both brake and abs fluids are fine...and my "expert" mechanic could not figure out what the problem was and suggested i go to a honda dealership to have them check it out...)
so, i have the pdf which shows what the codes actually mean, but question is....
1) where are the fuses/wires to perform this test?
2) which fuses/wires do i test?
3) what does it mean to short the wire(?) with a paperclip?
4) where does the code, flash, information appear?
sorry for the flurry of questions, but i can't seem to figure this out and really dont want to go honda shop just yet (*chi-ching*) for something that i can possibly diagnose myself...
thank you much....
thank you much....
