My car has this clicking sound everytime i turn the wheel while im driving. Anyone know whats wrong?
Clicking sound when turning
your outer cv joint boots on your front axles are likely ripped open and need to be replaced
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
to do it yourself you need a 17mm wrench break lose the bottom balljoint from the LCA need a 36mm for the axle nut and a long ass pipe to get some leverage to break lose that bolt if you dont have an impact gun.... a shop will charge you about 100 bucks an axle to fix and just becuase it licks both ways dosent mean both of them are bad.... just have to get under the car to look and see.... but also just because the axle boots are still intact dosent mean they are still good
This is a very easy fix, and a great place to get started in do it yourself maintence. You are looking at 200+ per side at my shop, VS 100 -150 total if you DIY. take the remainder you would have spent at a shop and buy a decent set of tools. That is, if you want to get into fixing your own car, i highly recommend it if you are going to own 14+ year old cars
