clutch fluid leaking help please
    whats goin on folks. if someone can help me with this i would greatly appreciate it,,the little accordian lookin rubber boot that runs off the side of thebleeder piece is leakin out all my fluid and not allowing the pressure i need to make the car go in gear. how can i take the bleeder thing off to replace boot,, its killin me,if anyone reads this and helps thanks,peace
    Replace slave cylinder. 2 bolts and then you need to bleed it.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      remove the 2 bolts on the bottom, bleed it then remove (you are taking off the clutch release cylinder) or slave cylinder
        i really appreciate this but the other problem i have is aside from the 2 bolts on bottom i cant figure out how to get it off that big arm that moves in abnd out(the arm that runs to trans
