My car has had an ongoing issue that is starting to get extremely annoying. I can be going any speed and my car will start sort of stuttering. I'll be trying to accelerate, but my car just won't gain any speed and you can feel it jolting. Then if you floor it, it'll go, but as soon as you let off, it starts doing it again. We were thinking it was maybe my TPS, but I was told that my Check Engine light would come on if that were the case, which it doesn't. We've replaced my distributor,cap, rotor, plugs and wires and that didn't help... Any suggestions?
Help please!
Tags: None
vacuum leak, fuel filter bad, clean the fuel system, check timingOriginally posted by theAcornMy car has had an ongoing issue that is starting to get extremely annoying. I can be going any speed and my car will start sort of stuttering. I'll be trying to accelerate, but my car just won't gain any speed and you can feel it jolting. Then if you floor it, it'll go, but as soon as you let off, it starts doing it again. We were thinking it was maybe my TPS, but I was told that my Check Engine light would come on if that were the case, which it doesn't. We've replaced my distributor,cap, rotor, plugs and wires and that didn't help... Any suggestions?
EDIT: i just saw a pic of you. holy shit your a cb7tuner chic. post up more pics. and your car looks flawless.Last edited by quickangel93; 09-24-2007, 11:39 PM.miss my turbo cb7
I know this thread is over a year old, but I need to bump it... The issue with my car is the same (see OP), but it's gotten REALLY bad, as in it does it all the time now. I didn't have the time or money to mess with my car with I made this thread, but I have to do something now. My CEL has been coming on randomly, so my boyfriend checked the codes and coolant temp sensor and O2 sensor come up. I plan to replace them in the next week or so. Do you think that could be causing the problem? I really want to start cheap to find the issue because I don't have the money to waste. Also, does it vary from car to car whether there are two O2 sensors? I'm not sure if my car has one or two. Thanks for the help!!
I owned a Pontiac Sunbird and when the o2 sensor went it would do the same thing you described. I could accelerate up to about thirty ok and once there is would shutter...almost like it was only firing on two/three cylinders. As soon as I replaced it, back to normal! I definately think the o2 sensor would be a simple quick cheap shot at your problem!Originally posted by theAcorn View PostI know this thread is over a year old, but I need to bump it... The issue with my car is the same (see OP), but it's gotten REALLY bad, as in it does it all the time now. I didn't have the time or money to mess with my car with I made this thread, but I have to do something now. My CEL has been coming on randomly, so my boyfriend checked the codes and coolant temp sensor and O2 sensor come up. I plan to replace them in the next week or so. Do you think that could be causing the problem? I really want to start cheap to find the issue because I don't have the money to waste. Also, does it vary from car to car whether there are two O2 sensors? I'm not sure if my car has one or two. Thanks for the help!!
Hopefully that will fix the problem - it would make me ecstatic!!Originally posted by Cwcb71990 View PostI owned a Pontiac Sunbird and when the o2 sensor went it would do the same thing you described. I could accelerate up to about thirty ok and once there is would shutter...almost like it was only firing on two/three cylinders. As soon as I replaced it, back to normal! I definately think the o2 sensor would be a simple quick cheap shot at your problem!
Can anyone answer the question about the O2 sensors. Do only some cb7's have two? I'm not sure if mine has one or two. I'd like to call and get some prices while I'm at work, so I'll need to know that.
our accords only have one.
depending on which engine you have, it could be right there in the exhaust manifold (F22A1) hidden by the heat shield or it could be under the car just slightly after where the two exhaust pipes come into one but before the catalytic converter (F22A4/A6).
to see which engine you have theres a small flat area right in front of where your front engine mount is. or look for the radiator hose that is coming from your engine that goes to the top of the radiator. it's right under it.Last edited by Leung; 10-06-2008, 02:34 PM.
cool, good luck with it. oh yeah if you do have to get a new o2 sensor, make sure to buy a genuine Honda one because the Bosch ones from the autostores don't work too well in our cars.Originally posted by theAcorn View PostThanks guys. Hopefully I can get this taken care of this week. I'll update on whether it fixes the problem or not.
Cross your fingers for me!
Ok, thanks for the advice. My boyfriend actually works for Honda, so I get a little discount.Originally posted by Leung View Postcool, good luck with it. oh yeah if you do have to get a new o2 sensor, make sure to buy a genuine Honda one because the Bosch ones from the autostores don't work too well in our cars.
I got hit by a drunk driver in April, so the passenger side rear quarter panel is f*ed and I have no passenger taillight. :-\ My poor car.
