i have a 93 cb7 and i have an cold air intake exaust but i want more power is there a mod chip or a turbo for this motor (stock ) if there is let me know where i can get them. im also looking for carbon fiber headlights and tail lights used and cheap.... wont let me add pic of my car sorry but let me know please
looking for more power i need help
try ebay for any accessories ,but when it comes to power,it depends on how much you want and much you willing to spend.
if you want cheap and quick ,i'd say go spray (NITROUS).
turbo on the other hand ,do a lot of research on it first.
there's also have a search button ,just type in whatever you want and it'll have an answer for you
most of these question had already been discussed before.
Good Luck,
There is an entire site dedicated to modifying the CB Accord. You will find a wealth of information there. It is called: www.cb7tuner.com
Take a look around there, learn a little, and come back with some more specific questions. From the sounds of your question, you've already done all you can do with the abilities and knowledge you currently have.
Here is a good place to start BEGINNERS GUIDE TO MODIFICATION
And DIY: How to Post Pictures
There is plenty of other material to read and take a look at on here that will be benefical as to what options you have.. Later
Best bang for your buck would probably be having your cam reground with a good performance grind. If you can't do without your cam for an extended period of time (e.g. daily driver) buy a good core from a salvage yard or keep your eyes out on eBay. A performance grind on a cam typically runs around $300.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
I built a turbo kit for about $600.Originally posted by dorbyu need more mechanical edumacation or lots of money before you start modding lol...a turbo will not get u power..a turbo kit...ur looking to spend 3k minimum with no idea what ur doing
It's not hard to do, and you don't need to know THAT much... read up for a week, and you'll understand what you need
A cam regrind from Delta is about $100. A NEW performance camshaft will usually run about $300.Originally posted by CamuraiBest bang for your buck would probably be having your cam reground with a good performance grind. If you can't do without your cam for an extended period of time (e.g. daily driver) buy a good core from a salvage yard or keep your eyes out on eBay. A performance grind on a cam typically runs around $300.
