My left turn signal does not work. The lights on the dash does not light up and blink, neither does the front or rear turn signals. But the hazard works just fine and so does the right turn signal. I have replaced the turn signal relay. I have replaced the stalk switch and I have checked the fuses, even the one on the driver's side(the one that's separate from the fuse panel. With the lights working whenever I use the hazard tells me that the wiring to the lights are good. Also, I have searched the forum and still found no solution. Anybody have any ideas?
Turn signal problem
Sorry for bumping an old thread but was there a solution to this problem?
Did a search and this thread came up.
A friend's car is doing the EXACT same thing (right turn works,
left turn dead, hazards are fine). Changed the relay and
the turn signal switch with known good ones but still no fix.
