f22b build HELP
    f22b build HELP
    ok so i just bought my self a f22b jdm eninge wooo!! ok now for the fun stuff performance ok so i know what i want or have a good idea i know i want to get stage 2 cams,springs and Titainium retainers and cam gears from bisimoto. and a full pully set and underdrive crank pully from U.R. and other assorted thing that are extrenal that i dont have questions about. but what i need to know is on the forum but there hard to understand or incomplete. 1st off for the cams from bisimoto to get the stage 2 regrind i take it i send them the cams i have and they regrind them to the stage 2 specs.? and then the instalation of them i read a post on the instalation of them and the adjustments and that just went right over my head....and then another newb question would it just be best to put them while i already have the engine out? ok on the pullys now i was reading and when i put the new pully set on i have to get new sized belts because of the new pullys and i was wondering what size i needed and also because of the engine swap and the bracket swap from my currect cb7 engine to the f22b. and if theres any thing i have left out or y'all think i should i know plz let me know.
    -and yes i have used the search button helped a little but not enough.
    Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
    bump.....any one?
      Contact him and ask. I think he sells Stage 2 cams.
      I got my 260 regrinds(sp?) from Delta. Those I know you send in and they regrind.
      Yes, it would be easier to put them in when the engine is out. I remember it was a bit of a hassle to put my cams in due to the space you have. It can be done but it is easier to do it with the engine out.(more room to move)
      EDIT: You will need an H23 timing belt.
      This link might help if you haven't read it yet.
      F22B DOHC Swap link
      3 CB's gone....
      1 WK Overland....
      Still miss the CB though......maybe one day.
        ok so if i get a full underdrive pully set for the f22b can i just swap out pullys and use the belts that fit since im just going to swap the altinator and ps pump and ac and leave them on the f22b bracket? when i drop it in or should i get the one for the accord and use the accord bracket on the f22b? and were would i get the belts for the pullys im guessing auotzone or some thing and what belts would i need like sizes and all
          really depends what underdrive kit you get. they should come with whatever size belts they use
            ok and do they make any after market intake manifolds for the f22b or can i use one thats for a h22 or does it matter. and one more question the ac compressor i use the f22a bracket but do i use the compressor also from the f22a?
              My JDM F22B didn't come with the A/C compressor so I had to use my A/C and the A/C belt from my a1.
              EDIT: As for the intake manifold, I don't really know. I haven't looked too far into it. sorry.
              3 CB's gone....
              1 WK Overland....
                ok kool good news on the ac and then on the underdrive set from UR they come with the belts i guess and so would i get prelude pullys or accord pullys and sorry for the question i just want to get my list together since i will have $1700 in my pocket soon and i want to do this thing right. any thing y'all want to add would be great be it parts i should get and any other bits of info.
                  another question does the power steering line for thje f22b engine fit right for a cb7?
                    Power steering line will fit the JDM pump but the belt will be short. That's why I had to lose my power steering till I get/find a belt that will fit.
                    I still have my power steering pump I have just been to lazy to put it back on and measure the distance around the 2 pulleys to find out what belt length to get.
                    3 CB's gone....
                    1 WK Overland....
                      Dude, seriously, go to the Swaps section. There is a shitload of information there.
                      Gary A.K.A. Carter
                      [sig killed by photobucket]
                        io have been looking around but most of it is broad doesnt say any thing about the pump line. so yeah
