As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Starting problem
    Originally posted by Alex13mod
    ITS NOT BATTERY CABLES, I CLEANED THEM AND FIXED THE GROUND ON THE FENDER. WHEN CAR IS OFF I HEAR A NOISE ON THE DIZZY LIKE IT STILL GETTING POWER. but when i jiggle the plugs from the dizzy it turned off , or i disconnect the battery the noise goes off.
    the car turned off? Then you may have a loose connection somwhere in the wire. It could also be your coil.
    ~Nick~
      *UPDATE* Found out that one of my sensor is still receiving power after car is off. thats the noise its making. When reseting the ecu, the noise turns off.
      that sensor gets really F*** hot. So that may be the problem why it doesnt start when car is hot. maybe sensor gone bad or because the plug is receiving power even when car is off.
      1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
        *bump*
          if it is getting hot then there is a bad ground. Mind did that with the alternator bolt and i just tightened it down and it was cool after that. Has to be a bad ground or a wire going to the wrong place.
          ~Nick~
            how would i trace those wires?
              *BUMP*
              How can I stop that sensor to receive power? shouldn't it be off completely when car is off? Even if i unplug that sensor. The plug is still receiving power.
                *bump* this sucks im never going to get this prob fix . i'm getting close to either selling it as is or junking it.
                  I had a similar problem with a '92 Accord. The wires were corroded inside the insulation. I replaced all the battery wires and never had another problem.
                    well i kinda have the same problem with my ride but only it turns on and if i dont revv it, it will turn off on me but its just the first time though after i drive for maybe a minute it stays on or if i revv it and just chill it wont turn off same prblm??
                    ReP TeAm !!MaSsAcRe!!<----
                    In Da *8-0-1*
                    1991 Accord F22a1~swap-->H22a1 Turbo T/3
                    500+WHP
                      Mine doesnt turn off. when i turn of the car and try cranking it, then the car sounds like is cranking and im getting spark. So i dont know why its not firing up. Only happens after driving a while or leave the car off for too long.
