Who has installed The F20B SIR Motor?
    I have the motor for sometime now and i have finally decided to install it. Does any one have helpful hint to help resolve issues I might encounter when trying to install this motor? Bear in mind i am talking about the F20B SIR Motor with the blue top. My F20B is an automatic with tranny. I have a 93 Accord Automatic I want to put it in. Any help is appreciated. Thanks in advance.
    OBD2-1 Conversion and the rest of the wiring should be covered in the swap stickies in the swap section. Its on the top of the page but it will tell you how to do all the rest of the wiring. It should drop right in like the h22a.
    EDIT You might have to do something with the trans though since its tiptronic as i recall on those.
      I just installed one in a customers 98 accord converted to obd1, if you have any questions PM me
        sweetness!
        if ur F20B came with the tippy, plunk it in man! use the tiptronic.
        Click sig to view MR thread
        Links to other rides:
        Honda Accord Euro-R
        Honda Odyssey Absolute
        Honda City I-DSi
        Honda Stream
          Okay here what i got so far...
          Okay here what i got so far. I have a Automatic 1993 Accord. I have a Pretty much complete Sir motor i.e (F20B engine, ECU, Automatic Tranny). Dont I totally skip the OBD1 Conversion since I have an OBD2 ECU? I am so confused.
            Your car is OBD1 and the engine/ecu is OBD2 you have to convert in order to adapt....
            Just taking a stab at it, but I think that is right.
            Check out ESP engine mount kits for your CB7!!!
              how will your obd 2 ecu plug onto your obd 1 connectors??
              and the injector wires for the power and signal are different. there are more to it than that though. But I do not have all the answer. the easiest, h22 intake manifold and inectors (obd 1), obd 1 p13 ecu and tcu. expensive way, send your harness to hasport and have them rewire your engine harness for you to fit that motor.$$.................. OBD (On Board Diagnostic) obd2 is all cars from 96 and up. Different emissions and plugs etc.
                Need The Wiring Diagram...
                I need the diagram of the wiring of the F20B Auto ECU? Can anyone help me? I want to get this one shop to make the wiring harness for me so i don't have to splice my own wirer. To complicating for me.
                  Why splice it, go to Honda, ask them for a wiring harness for that year motor, although it might cost ya a bit.
                  90 Accord EX F22a1 Auto R.I.P.
                  2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                    since u got all the stuff for the conversion
                    go the OBD-II route buddy, presuming u got the whole CF4 wiring loom
                    uve got the ECU+TCU (they are one unit, unlike the original ECu and TCU which are separate)
                    and keep that tiptronic
                    i regret not finding the TCU for my transmission (taken from a BB6)
                    Honda Accord Euro-R
                    Honda City I-DSi
                    Honda Stream
                      &quot;I need Wiring Dragrams!&quot;
                      I am still to new for all this. If you have a writen setup I am willing to try it out. But as of now I just want to take the most simple route that even me and my buddy could do. "I need Wiring Dragrams!"
