f22a Head Milled to the max
    i got af22a head second hand.it has been ported so im trying to save it.problem is it has been milled so many times. machine shop said it was shorter then the minimum, and i actually need to shave the surface. its so close it would cut a valve if he resurfaced it. so i removed the valves looks like the valve seat will be ok. i am worried about bending valves, i also have a aftermarket bullfrog cam. f22 parts has a head gasket 1.07mm thick... so that should work. anyone know how what hieght my head needs to be before i bend valves?
