Well some one try steal my car but what they ennded up doing is getting a flat head in my ignition lock I bought a new one BUT I HAVE NO IDEA ON HOW TO INSTALL CAN SOME ONE HELP ME HERE......
ignition lock and key
Here ya go....
Check out this thread http://www.cb7tuner.com/vbb/showthre...nition+removal so you can get a good overview of the entire assembly, just for reference. The thread shows how to replace the entire switch and assembly, so you don't need to do all of those things in the thread. Just look at it for reference. What you need, from the sounds of it though, is only to replace the LOCK CYLINDER. That's the part the key goes in. Here's my little DIY for the LOCK CYLINDER:
At autozone or similar places, the replacment cylinder/key is about $20. The fitment is iffy, but it'll work if you're on a budget.
1. Just take off the steering column top and bottom covers (unscrews at the bottom).
2. Adjust the steering wheel to the lowest position so you have the most room to work.
3. Unsnap the White plastic ring from the end of the cylinder. (the one that lights up blue at night).
4. Using a small micro phillips head screwdriver, unscrew the tiny screw at the top of the cylinder just above where the key goes in.
5. Turn the key to the "I" position...
6. Next to where the tiny screw was, there is a little copper-coloured "button" inset in a tiny hole. Push that in with your micro screwdriver as you use your key as a handle and pull the cylinder out.
Installation is the reverse of removal.Last edited by BlackPearl2006; 10-26-2007, 03:34 PM.
