I am slowly working to fix this car, coming to them as money allows and the importance of the fix. My delema is struts at the moment. I'm not looking for the best of the best but I do want quality products, and I don't want factory replacements. Also, I HATE doing anything twice if I can avoid it, especially when it comes to money. So...later down the road, this car will have 18" wheels on it but for now we're stuck at 15". So...I need a semi-economical strut that will work with what I've got goin on wheel size now, and later. Can someone point me in the direction of a decent coilover/spring set and ummm...will I need chamber correction kit with them?
Suspension
dont use an coilover sleeves on a strut they suck and real coilovers well cost u at least 800 which doesnt sound to be in your range 1st u have to decide how low of a drop u want i like 2-2.25" its a good drop without compromise of performance many diff. companies r good i like sprint springs but there are others they all run around 150-200 and for a good strut non-adjustable totico blues r decent or kybs but i heard they hold ur car up higher
BB6 2001 Prelude SH
Originally posted by Makaveli2kDon't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
=p
Everything can always be painted so don't buy it because it's blue. Buy it because you think that your car will ride best on it. If you purchase a shock absorber that is a terrible match to your spring rate you won't care what the color is because you will hate the ride. Read the suspension forum side of this website and you will realize that if you truly want to only do things once, you can't cheap out and you can't pick things based on color."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
