ok now that i know where the computer is at....can someone explain to me the difference between all the different kinds..i went on ebay and i saw that there were like 7 different types of ecu...people help me again...thanks
computer help 2
Well there's like a thousand different ECU's haha. Each ECU is different for each car. The difference is in the "tune" of it per say. Like if you take the ECU from a cb7 and put it in an s2000...the s2000's going to suck shit. Our ECU's tuned to run a specific a/f ratio with our cr, our header design, intake port diameter, fuel injector size...yadda yadda yadda. If you want to get into specifics, hit up Wikkedv16 or MRX...they seem to be the ECU guru's around here. Probably others, but I'm still a noob so I'm still learning people. But check out this thread by MRX on ECU's.
http://www.cb7tuner.com/vbb/showthread.php?t=10335
^^click it or ticket^^
What's done to your car? A new ECU won't help you at all unless you have the mods to support it.
PT6 comes from an F22A6 (92-93 EX motor), and will only give gains if you have the other A6 parts.
P12 comes from an F22A1 powered Prelude. This might give you gains if you have an F22A1or F22A4. Not sure if it would help an F22A6.
Unless you've swapped or boosted your engine, you won't have any use for anything else.
like mike said... youwon't need anything other than the stock ecu unless you have upgraded or boosted or swapped. you can for little money bring your a1 or a4 to an a6 and use the pt6 ecu( which i have one for sale from mine a 5spd too) or you can run a chipped p28 or chipped p06(also have p06 for sale) and tune almost infinately for your setup. otherwise youaren't gonna get anything out of it if it will run at allMy other ride is your ex-wife
